SOLD AVA 15" & Viper d1200.1
Naxis2k1
grade A whiteboy
598
Phoenix
Just as the title says.
Both Items are 100% operational. Reason for selling is I just had a baby girl and daddy needs room in the trunk now for lots of other items. Please PM if you are interested I will check everyday after work.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
HELP A NEW DADDY OUT! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
AVA 15" is a great subwoofer one of the better i have used XBL2 motor. There are some visable scuffs on the surrond and basket. 8.9 out of 10 for cosmetics. $190 plus shipping only in the U.S. paypal only plz
Avalanche 15:
Qts - .305
Qms - 3.5
Qes - .334
Vas - 300.6 Liters
Fs - 15.7 Hz
Re - 3.2 ohms
Znom - 4 ohms
Le - 2.4 mH
Mms - 269 g
Vd - 4.04 L
Xmax - 27mm
800 Watts Rms
Sd - 749 sq.cm / 116.09 square inches.
Viper d1200.1 mono block amp 10 out of 10 for cosmetics. dont think they make these any more, too bad there are some great amps:verymad:. $190 plus shipping, paypal only plz
Dynamic Power Rating: 1500 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 450 x 1 (underated)
Rated Power @ 2 ohm: 800 x 1 (underated)
Rated Power @ 1 ohm: 1200 x 1 (underated)
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
800 rms, it can take a little more though
Definitely can. Somewhere in the area of 1300 was what I was feeding each of my Avalanche 18s when I had them. $190 is quite a deal.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Here are specs for the 15.
Avalanche 15:
Qts - .305
Qms - 3.5
Qes - .334
Vas - 300.6 Liters
Fs - 15.7 Hz
Re - 3.2 ohms
Znom - 4 ohms
Le - 2.4 mH
Mms - 269 g
Vd - 4.04 L
Xmax - 27mm
800 Watts Rms
i love the viper 1200D but i doubt that it is underrated.
they also dont make em anymore.
not post dumping, just giving facts
gl with your sale.
whats RMS on ava, and do you know what rec. box size for that would be?
800rms as stated above but they handle more without a problem. I Know a couple of people sending 1500 rms to there AVA. I wouldnt exactly recommand that but it does seem to be able to take it. I Had this unit is a 2.0 cft box sealed. One of the more natural sounding drivers I have used. Great response on the low end.
Thanks for the stats DUKE
interesting. i stop into my way to quad cities everyday on my way to iowa for work. do you live by that BP where the banner says IOWA smokers welcome
121
359
  • Locked
662
Amp
479
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Naxis2k1
    Jun 1, 2024
    May 31, 2024
