Sold AVA 15" & Viper d1200.1
Naxis2k1
grade A whiteboy
Just as the title says.
Both Items are 100% operational. Reason for selling is I just had a baby girl and daddy needs room in the trunk now for lots of other items. Please PM if you are interested I will check everyday after work.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
HELP A NEW DADDY OUT! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
AVA 15" is a great subwoofer one of the better i have used XBL2 motor. There are some visable scuffs on the surrond and basket. 8.9 out of 10 for cosmetics. $190 plus shipping only in the U.S. paypal only plz
Avalanche 15:
Qts - .305
Qms - 3.5
Qes - .334
Vas - 300.6 Liters
Fs - 15.7 Hz
Re - 3.2 ohms
Znom - 4 ohms
Le - 2.4 mH
Mms - 269 g
Vd - 4.04 L
Xmax - 27mm
800 Watts Rms
Sd - 749 sq.cm / 116.09 square inches.
Viper d1200.1 mono block amp 10 out of 10 for cosmetics. dont think they make these any more, too bad there are some great amps:verymad:. $190 plus shipping, paypal only plz
Dynamic Power Rating: 1500 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 450 x 1 (underated)
Rated Power @ 2 ohm: 800 x 1 (underated)
Rated Power @ 1 ohm: 1200 x 1 (underated)
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
800 rms, it can take a little more though
Definitely can. Somewhere in the area of 1300 was what I was feeding each of my Avalanche 18s when I had them. $190 is quite a deal.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Here are specs for the 15.
Avalanche 15:
Qts - .305
Qms - 3.5
Qes - .334
Vas - 300.6 Liters
Fs - 15.7 Hz
Re - 3.2 ohms
Znom - 4 ohms
Le - 2.4 mH
Mms - 269 g
Vd - 4.04 L
Xmax - 27mm
800 Watts Rms
whats RMS on ava, and do you know what rec. box size for that would be?
800rms as stated above but they handle more without a problem. I Know a couple of people sending 1500 rms to there AVA. I wouldnt exactly recommand that but it does seem to be able to take it. I Had this unit is a 2.0 cft box sealed. One of the more natural sounding drivers I have used. Great response on the low end.
Thanks for the stats DUKE
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Naxis2k1
