HillTownBoss
Does anyone know anything about these new Autotek amps I want to know if there any good or not let me out here guys the specs on it is:
1-Channel Operation
Mono-Block Amp Design
375 Watts x 1-Channel @ 4-Ohms
750 Watts x 1-Channel @ 2-Ohms
1500 Watts x 1-Channel @ 1-Ohms
A/B Class Amplifier Topography
Stable @ 1-Ohm Speaker System Load
Pro-Fi MOSFET Outputs
ASPS (Auto-Step Power Supply)
Road Worthy TCID (Twin-Coil Isolation Design)
Fully Adjustable Pro-Design Crossover
24dB Subsonic Filter
24dB Low-Pass Crossover
Bass Thrust
Variable Bass Equalization
Remote Bass Control Included
RCA Line Outputs
Permits Amplifier Daisy-Chaining
4-Guage Power Connectors
SPECIFICATIONS
Amplifier Class : A/B Class Amplifier Topography
Number of Channels : 1-Channel
Maximum Power : 1500 Watts
RMS Power Output @ 4 Ohms : 375 Watts @ 1-Channel
RMS Power Output @ 2 Ohms : 750 Watts @ 1-Channel
Bridged Power : N/A
THD : 0.10%
Signal-to-Noise Ratio (dB) : 95dB
Frequency Response (Hz) : 15Hz~300Hz
Built-in Crossover : Yes
High-Pass Crossover Frequency : N/A
Low-Pass Crossover Frequency : 40Hz~150Hz
Bass Boost : 0dB~12dB
Bass Remote : Yes
Fan Cooled : N/A
Fuse Rating : 50A x 2
Dimensions (Width x Height x Length) Inches : 9.4" x 2.3" x 20.08"
1-Channel Operation
Bass Thrust
RCA Line Outputs
SPECIFICATIONS
Bridged Power : N/A
THD : 0.10%
Bass Remote : Yes
Fan Cooled : N/A
