Audioque or AudioPipe?
If money isn't an issue the AQ is a more well built amplifier, however if you are running a 2ohm nominal load, you won't be pushing the amplifier that hard anyways, and the Audiopipe will do just fine. On the other hand, if you were going to try dropping to 1/2 ohm nominal, then the audiopipe would be a poor choice.
The AP 3k is only 2 ohms stable, it's basically 2 amps strapped together.
bigger audiopipe amps do rated but barely and not always with a very clean signal, audioque delivers over rated clean power and better made. just get an aq2200 and be done with it, you will be pleased.
to be fair the OP said he only needed 2000 @ 2
Dirtrider4eva
√\_The CaUsE__
Dirtrider4eva
Milwaukee, WI
Dirtrider4eva
