AudioQue HD3-15/12
id shoot for 40hz cause it'll perform as if it was tuned lower //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But, I need my lows....this is for a daily driver for rap/Hip-Hop music.....
wouldn't 40hz kinda eliminate the lowness and sound quality...
Plus, I emailed DJ (dude from AQ) and head said 35hz for daily music....
but I heard otherwise for actual end users. So, thats why I made this thread.
i listen to the same type of tunes, 40hz slams for sql //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
so you're finally going to buy something?
if DJ says 35, then do 35...whats the big discussion?
i don't know who you've heard otherwise from but MOST people here got their suggestions straight from the source, and thats DJ himself, and he recommends 35-40
don't need to question why DD's are tuned higher then usuall, if you've searched, then you'd know...
Yep. And when two Audioque users say to tune to 40hz, then you should //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I've tuned lower before and the SQ goes to crap IMO. The lows stay the same output wise, but there's a steep dropoff around 50hz. It is dependent on car/box size, but that's what I've found out by messing with this sub.
Do 35hz and if you dont like it change the port to 40hz. what kind of port you using?
x2!!! it is always easier adjusting a port from a lower frequency to a higher one, just cut the port length a little //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
grillman6000
¿ G0t ThUmP ¿
grillman6000
Margate, FLORIDA
jmanjr
