Audiopipe apcl1500.1d overheating
I have a fairly new Audiopipe apcl1500.1d pushing 2 12" precison power p12.d2 D4ohmVC rated at 800rms each.
I have them wired at 1ohm and yes the amp is stable at 1ohm its giving them about 1300rms total @1ohm
My problem now is that after 15-20min my amp will go into protection mode until it cools,i have my gain about a 1/4 of the way and its hitting pretty darn good.
Any suggestions on how i can prevent My amp from overheating?
Also i havent yet upgraded my stock alternator or added and extra battery but i do have a 500k capacitor. Could the lack of power supply be the problem?
What's your voltage at the amp like? Either your over working the amp/asking to much from it or there is no ventilation and the amp can't cool itself.
About 14.0-14.1 and i have the amp in the trunk on the floor in front of the box with the seats down when im blasting it
Might have to switch that 4 gauge to 2 gauge.
Also have you done the big 3 yet? Battery/alt can be had at a later time...unless you got the $$ to spend now, but it's up to you.
I'd do the big 3 myself 1st tho...
Haven't done the big 3 yet but i will go that way soon,i have two big computer fans that ill probably throw in under the amp by the vents on an amp rack im building tommorow
Madwelderlupe
Madwelderlupe
Fort worth
Madwelderlupe
