audiopipe 1800d
i was gona get a audipipe 1500d and run it at 1 ohm . i wana know if i run the 1800 with the wire and battery im gona get is it worth the 25 for the 1800 to give me some head room? i have ran a sundown 1200 and audioque 1200d with a small battery in the back and my voltage was not bad at all.
amp - audiopipe 1800d @1 ohm 1300rms its gona b less do to volt drop etc
wire- 4 ga kicker
back battery-deka 9a31's
alt -stock 70-80 /grounds under my hood down with 1/0
subs- see sig
i know 1/0 knu is the best bet, but i wana add the 4 ga is in my car and it was used for my past few setups. i can get some wire form a member from here. he is local but if u guys think i can save the 30 - on wire i could put it towards some bills lol. thanks
You'll be fine if the sundown and Audioque gave you no problems.
thats what i was thinking, but those 2 amps are less power hungry amps. i have no issue with going with 1/0 but if i could save the money i sure do need it lol. been sick missed a few days for my up and coming pay check. lol
yeah let me know how it performs i need a bigger 1 ohm amp
im just geting everything done, i think im gona get one of these. i wonder what fuse it comes with. the 1500 comes with 100 anl and it is 2 small. i have a few 150 fuses is that good for the ap1800? keep in mind i have a 150 nder my hood and one ready for my back battery.
I would get the MB Quart 1500d. The audiopipe 1800 is basically the same amp as the 1500.
i could use the few hundred watts to b honest. im just trying to get as much info as i can. im gona order from knu for some wire and there anl fuse are like 6.00 and i would need lke 3 or 4 if i have to bump up my 150. im not a fan of the mb quart.
You would be much better off with something else. The 1800 doesn't do rated.
well im gona order my new amp in a day or so. 1500d or 1800d . the 1800 will give me a little head room. i just wana make sure my 4 ga and my back battery will do the job. the 1800 will b at 1 ohm and set for 1300-1400rms. the 1500 will b at 1 ohm and set for 1200 rms or so. we know there will b some kind of voltage issue so im sure i wont b seeing the full 1200+.
1rockford1
Banned
1rockford1
soon to be upstate ny
Max_Power
