Dustee83
SO I've just upgraded my sound system in my 2006 Focus.
I Have a sony Headunit with 2x pre-outs (front & sub/rear)
2x BassFace DB2.1 (2/1 Channel Amps)
Vibe Slick 6C Component Set (in custom made rear mdf shelf)
JBL GTO 12" Subwoofer in custom built false floor (spare wheel well)*
- Having installed the system as follows:
Fitted head unit used factory wires and front door speakers
Spliced new cables to rear speakers on custom shelf (temporary until can get amps working)
Wiring kit -
4AWG power cable from battery (awg80a inline fuse at battery)
Cable runs into a 4way distribution block with 4x independent awg40a fuses) then 1 8awg power cable to each amp. 8awg earth cables from each amp to singular earth point properly grounded scratched down to bare metal and fitted with bolt.
Remote cable fitted to both amps.
NOW the HEADACHE!
Both amps power up (green LED) also custom fitted 2x led 120mm fans to them which power up from the Remote on with the amps just for a nice added touch and aid cooling.
However I get No sound from either amp via sub or rear speakers.
- Volt Tested the amps 12.8 volts on power cable to both amp with engine / stereo off - dips to 5.8 volt when stereo is on
- Volt Tested the Amps 1.3 volt on the remote lead when ignition/stereo is off - increases to 12.8 - 14.8 volts when stereo/engine is on.
- volt Tested both grounds to an independent ground and both read 0 volts
- Powered up BOTH amplifiers and hooked upto speakers / subwoofer on a 12v power supply for bench test.. ALL WORKS PERFECT in bench environment.
Used known working RCA leads..
Tested RCA outs on a secondary head unit (known working) still no sound in car!
Any idea what I could be missing?! I'm absolutely confused to hell right now
Wiring kit -
NOW the HEADACHE!
