audio shop i went to...?
stangpounder
Wi
ok i went to the audio shop where i live the other day. asked them to demo a tpye x for me... well they decided to take my (15"cvr) out and put in the (type x) and hook it up to my amp (1000.1bd) listened to it for like 20 min.
1st of all it sounded like A$$ imo compaired to the CVR i have in there
2nd they tried telling me it was because my RF1000.1 didnt put out 1000wrms???? i didnt know that to be true.
& 3rd the subs cone was really hot and the sub sounded distorted *** heck and smelled like it was going to blow??
so my questions are are these people idiots? dose my amp not put out 1000wrms? and dose the type x ****? i think it was in like 2.75-3^ft ported low
If they didn't have the Type X wired to 2 Ohms then it wouldn't have been getting 1kW from your amp. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
That would be my 1st guess, anyway...
yeah, I had my type x off if the T10001bd and it was only getting about 700-800 watts cuz my sub was a D4 and the bd is 1000 at 1 ohm. But it still sounded amazing. I loved it, louder than my eclipse 15". Maybe the shop was using a sub they abused the shit out of.
there is no such thing as a type x 15?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused:
maybe they just came out with one. idk
it was a 12" i didnt say a 15" i dont think...my cvr is a 15 and i dont know what they did but imo they made my 90$ cvr sound like "the sh!t" cuz that type x was soundin "like sh!t" and they tried to charge me 500$ sub and box
Type-X 12" is optimized for sealed box use. Weak motor (high Qes/Qts, Low EBP) and models with an extremely low anechoic F3 in a moderate sized sealed enclosure. Extremely sensitive to misalignment or poor FR in a vented enclosure, especially when coupled with vehicle transfer function (cabin gain), and especially if the enclosure was not designed properly for this particular driver.
Try auditioning it in a 1.5 ~ 2.5 CF sealed enclosure and compare it to other drivers that are optimized for medium-sized sealed box use and have similar Vd capability.
This is a rather unique subwoofer design however.
500? you can get the type X for 180-220 online..
The type X should get 1000 watts, your amp is probably 1000 @ 1ohm like everyone suggested
also the type x is a funky little sub that has jumpers or w/e they're called, I know some other subs have it but i hadn't upgraded in a while so it was new to me //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it should be in a .75-1 cu ft box I believe, not a 3
if it's vented then i think 1-1.25? im not as sure on the second one
I own an swx-1042d, and I am only giving it 420 until I get my mm1400.1 back :[
to be honest, it sounds like shit even at low volumes
then again I also bought it used
and the previous ******* owner only hooked up one coil to 1000 watts (no jumper)
When I took it out of the box it smelled like something had burned previously
It plays better now after some adjustments, but I can't give you a definite answer until I get a stronger amp for it
700 watts is probably what your amp put out if it's 1000 at 1 ohm, but even then that should be plenty good..
The specs I found for the Power 1000.1bd lists 500w @ 4 Ohm and 1kW @ 2 Ohms //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I've either found some incorrect info or you're not remembering it correctly.
Hopefully someone who is a bit more familiar with RF gear than me will come along and sort it out.
I picked up an SVR there last summer. Wasn't impressed by the old guy or his son that does installs. Kept going on and on about JL subs being THE best by far and my car must sound like crap because I don't have an RTA to set it up, blah blah. I was just there for a battery and didn't mention my set up at all. He wanted to measure under my hood, etc... even after I told him SEVERAL times I would install it and that I already made sure it would fit.
Had a lot of decent equipment in the store, but the dog piss smell about made me puke.
I believe the $500 for sub/box, he's pretty proud of his shit.
I'm like 30 minutes from you, so if you get a sub and need a box built give me a holler.
stangpounder
stangpounder
Wi
BassAddictJ
