Audio Legion AL6500 18v stable
SounDrive
Pro Seller
www.soundrive.audio
3,114
Lebanon, TN
Audio Legion 6500
Brand new with warranty. open box unit. Did 7943W at 1 ohm at 14.8v CERTIFIED on the amp dyno. 9400W at 15.3v dynamic burst
RMS Power Ratings @ 14.4 V Input:
1625W x 1 CH @ 4 ohms mono
3250W x 1 CH @ 2 ohms mono
6500W x 1 CH @ 1 ohm mono
RMS Power Ratings at High Voltage
4 ohm: 2400W (18V) & 2300W (16V)
2 ohm: 4800W (18V) & 4600W (16V)
1 ohm: 9200W (18V) & 8600W (16V)
1250 shipped
Included
Typically amps operate with higher efficiency at higher impedence. So 1000 rms at 1 ohm but perhaps 600 at 2 ohm and 400 at 4 ohm. For example. I notice many amps rated at half the rated power at 2 ohm. Such as this amp. 6500 at 1 and exactly half of that at 2.
On Korean amps that is often a sign of a weak power supply that can't handle the full power of the amp. These Amos don't have that issue.
Ill check it out. I was actually on the site last week. Thanks!
406
I think you made a good choice
10
did you ever find out the specs of the sub and what it needs for perfect air space? i wanna find the mounting depth etc so i can build my box...
4K
Mad at myself for not buying a few of those subs to keep on hand. Got a few amps though.
24
4K
Just got 2 more amps and an eq that I ordered on Friday. Just not a bad price for matching amps and decent power. Got an eq thanks to @audiobaun...
SounDrive
Pro Seller
www.soundrive.audio
SounDrive
Lebanon, TN
SounDrive
    May 18, 2024
    May 18, 2024
