Audio Issues
MustangMafia
Hey guys, the problem I am having is a little hard to describe. My setup is a Sony Deck going to an Amp then to 4 6x8 Kicker KS680 speakers. Whenever I want to crank on a song (don't matter which) at a loud enough vol. it almost sounds like part of the bass in the song is dead in sound although i hear the other part of the song. I'm not really sure how to describe it. If you have any ideas on what my issue could be it would be greatly appreciated. Let me add that this didn't start until I was playing a song that had a great and loud guitar solo in it. The music sounds fine at lower volumes.
it would run really well for like a minute or less, and then it sounded like the volume just took a dive. everything sounded kinda flat like you were listening to it through a wall or something.
Tidalwave TXB4200, 400W amp, wired with RCA cables just 2 channel with the 4 speakers bridged. due to a set of bad rca cables when installed. I was going to wire as a 4 channel setup
rated 50rms@4ohms x 4, and my 4 speakers (Kicker KS680) are rated at
Peak: 360 watts per pair / 180 watts each
RMS: 120 watts per pair / 60 watts each.
well i tested the current RCA cables and thats not the problem. I wired it up in a 4 channel setup and getting the same problem but only on the rear speakers, which is the same channels i was running off of while bridged. Its either the Amp or the head unit, ill switch the RCA cable tomm. and see if it switches or not.
It turns out the problem I am having is clipping. Im not sure if its the pre amp in the Head Unit or the Amp in my trunk. Anything I can do to tell which? I only ran the Amp(Trunk) at about 35-45% gain at most. on 2 channels bridged to 4 speakers. I redone the wiring and is now 4 channels and is still clipping.
MustangMafia
MustangMafia
Thomasville, NC
MustangMafia
