audio control 4.1 eq
  • 2
audioman14
audio control 4.1
$130 shipped
Picture shows it powered on test bench and knobs back-lit, this can change between green and red. Comes with mounting hardware and power plug.
In-Dash Car Audio Equalizer with Auxiliary Input
Stereo Graphic Equalization
Para-BASS Low Frequency Controls
Pre-amp Gain: 20 dB
Line Driver: 13V Peak Output
Balanced Differential Inputs and Outputs
High-Headroom PWM Switching Power Supply
Main and Auxiliary Switchable Inputs
Switchable Backlighting Color(Amber/Green)
Master Volume and Fader Control
Selectable Ground Isolation
Optimum Voltage LED
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
audioman14
audioman14
Washington, D.C.
audioman14
    Apr 28, 2024
    Apr 28, 2024
