ATTN: PC Guru's
mjbailey21
Getting back into it!
Friend called me up with an interesting question. His desktop PC randomly stopped working! I went to talk a look at it and I have no solution. When it boots up, it stays at the Abit motherboard logo. When I press tab to see POST, it just has the memory running up. After good while, it tries to boot up. There it stops at "Update Succesful" where it says that before the XP logo normally comes up.
I cleared CMOS and it does the same thing.
When I try to repair with my XP disks, it says it cannot find a harddrive.
Is my HD dead?
Thanks!
Matt
maybe a bad sector in the harddrive. i had a similar problem once, eventually i copied all my files onto another harddrive using ms dos and reinstalled winxp
bump?
I am just trying to reformat now. When I change the boot sequence, and reboot to get to the xp setup screen, it asks to repair or continue installation and if i choose either it tell me setup must be exited because no hard drive was found.
Whats the other way I can go about reformatting?
bump?
do what your doing...reformat it, only way to problem solved, its corrupted //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
take the non-working hard drive and hook it up to another computer as a slave drive if you have another computer and format it in windows
mjbailey21
mjbailey21
Dallas, Tx
flakko
