FlexnInLa
Huggin Them Nuts!
It boots into safe mode. There is an alternate .exe for Malwarwbytes and SuperAntispyWare that generally WILL run in situations like this... but usually you can just rename the .exe to bullshit.exe or whatever you want to name it and it will run. Might have to do it in the folder and run it from there.
Malware usually doesn't use heuristics to determine what is trying to remove it, so simply renaming it generally works.
If that doesn't work you can change the file extension to .scr instead of .exe and it should install. At that point you might have to rename the .exe again after the installation, or change the file extension to .scr
But obviously, Spider Monkey is far more experienced and talented in situation like this... so if you want some help I'll be glad to give you a hand, just PM me so I don't have to come read Spider Monkey's "thanks for playing" when his only solution is to reinstall Windows. Quite the computer pro you are Spider Monkey, quite the pro!
