Attn Loud Trunks
thor... did you hook up that TL yet.......
Nope been working and shoveling an *** load of snow! :crazy:I'm going to go pick it up the weekend of the 24th( this month). Hope to get some testing done before Feb 22nd show in Ogdensburg! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Made Mom(the wife) a deal that the new laptop is hers. I'll just be using it for testing and running Comps. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'm hovering over Circuit City right now waiting to see if they go into liquidation mode. If they do I might just pick up 2 laptops. lol
I picked up the Kinetik 2400. Drove through some nasty snow storms to get it but I'm an addict what can ya say!
k guys my bro is redoin his system (which means he buys the stuff and i do it all)
98 nissan maxima with sunroof //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
2 aq sd 2.5 12's (amazing for 160 a piece IMO)
4 cube box tuned around 35hz with like 70 sumthin sq. in. of port.
1 crunch gp 3000d
1 kintek 1800 2 big deepcycle batts im borrowing from dad atm //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
stock alt and 1 run of 0 for power (getting a ground run soon tho)
hopin to do over a 145 meca style peaking at around 36hz. it should be hooked up by wed or thurs and ill deff have a vid and itll be metered at the end of the month:D
1 crunch gp 3000d
Look forward to seeing them! Depending on how big these other batts are ya may want to add at least 2 runsof 0.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Do me a favor and take a vid of placement of meter and stuff. I've never been to a meca event. THX!
it is a stand like 22 or inches high that ends up right around the headrest and any door or combination of windows can be open. low tuned ground pounders usually meter the best hence his amazinly music setup which peaks around 36 metering good. also best numbers are are usually had with the opposite door open and meter opposite the port in the car //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. we did a 143.2 at 37hz with 2 12in cvrs in the same box with only one batt and only 1kw so i think a 145 is a pretty conservative number im guessing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hmm i also have a youtube vid of the mtering but not of the inside while it was bein metered //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
it is a stand like 22 or inches high that ends up right around the headrest and any door or combination of windows can be open. low tuned ground pounders usually meter the best hence his amazinly music setup which peaks around 36 metering good. also best numbers are are usually had with the opposite door open and meter opposite the port in the car //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. we did a 143.2 at 37hz with 2 12in cvrs in the same box with only one batt and only 1kw so i think a 145 is a pretty conservative number im guessing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifhmm i also have a youtube vid of the mtering but not of the inside while it was bein metered //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Thanks! I'm gonna have to try that when I get my TL:D
1 crunch gp 3000d
Good luck man.. I've got the same car in the 99'. Hard as hell to get loud...how are you letting it breath from the trunk to the cabin?? That's been my biggest problem with all the **** sheet metal back there. Do you have fold down seats??
I'm about to get my HDC318 up n runnin tomorrow. Tried the Q, tried the RD...we'll see how she runs!
no. we took out the rear 6.5's (the flex actually broke 2 sets:eek:) that "sheet" metal is removable and is taken out and the only thing back there is seat and the middle thing is let down to help it breathe. i think he gains over .6 db with the seat fully out. yea its very loud atm with the two exta batts and 1 kw. with the gp 3000 itll be retarded and the box came out awesome and plays up to about 48 LOUD and down to about 33 LOUD. ill have to take sum vids. if i were u.... do 3 10's in the biggest box possible all facing back and i GURANTEE itll be louder than an off axis firing 18 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i remember when i did a vid on my car trying every org class that i would qualify for. we got to meca and had no idea how to set the meter. ended up holding it between the front seats, with the car sealed up. did a 43.X. i guess i will have to try it the right way next time i get a hold of a meter.
thorshammer1
thorshammer1
Auburn, NY
basshedz06
