Attn: All PG RSD owners.
Hearing your speakers without the doors deadened then hearing them with the doors deadened is like night and day. I got my rsds and installed them, sounded good but wasn't too impressed. I then deadened my doors and i was shocked, the midbass is incredible.
And to the person who is giving them 75 watts a side, you should double that. Make sure you set your gains correctly as well.
i dont own a set but alot of the owners say from new to break in they are like night and day. midbass comes when you deaden and when they break-in.
Treat your doors properly. This doesn't just mean deadening.
Also, keep in mind that one person's "midbass pounds" might be another's "midbass sucks". In other words, it's relative.
I was going to pick-up the RSD's (after trying to find something in the $200 range and better then the RSD's but no luck). Though had a few questions wondering if someone could clear up for me.
I have a 5 channel amp it's rated 4x130 1x400 @ 4ohms or 3x400 @ 4 ohms. (don't want to get into actual power since i cannot test for that or wouldn't even know how) I've been told I should run them active but would this entail me having to buy an external X-over if my HU can only go up to 125hz on the HPF? also i am not really experienced setting all that up would it be alot more work or overly difficult to figure out how to set it up?
I was toying with the idea to run my amp bridge for the more power. (Though I haven't come across any speaker in the price range I could spend that would handle that much power). So if I did run the RSD's passive and had the amp bridge am I correct to assume I would have to have the gains pretty low as too not send too much power to them and blow them up? or is mine line of thinking all wrong?
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
king ranch
michigan born
    May 14, 2026
michigan born
    May 14, 2026
