Are These Good?
shanerz21
WHICH ARE BEST?
INFINITY- Maximum Power Handling Of 135 Watts (peak)
Continuous Power Handling Of 45 Watts (rms)
Frequency Response From 67 Hz To 21 KHz
Sensitivity Of 92 dB
KICKER- 180 watts peak (90 each speaker)
90 watts RMS rated (45 watts each speaker)
Sensitivity: 90 dB
Frequency Response: 45-20,000 Hz
Impedance: 4 ohms
MA AUDIO- Sensitivity: 91.3 dB @ 1w/1m
Frequency Response: 70 Hz-22 kHz
60W Rms
120W Max
AUDIOBAHN- 80W RMS
60hz- 20 Khz
93dB
which kicker and which infinity? You noted that the Kicker were rated at 90RMS but 45 per speaker and the Infinitys are the same. Infinity is known for having a solid SQ sounding speaker but kickers aren't known to be that good unless its the SS series. Depending on which series would help make a better decision.
shanerz21
shanerz21
IOWA
alteraudiousa
michigan born
    May 14, 2026
michigan born
    May 14, 2026
