OP
bimmeracer
- Thread Starter
- #16
Thanks guys. I will check to see what I would need to do to make those 6.5's to work with an E36 BMW.
Edit: Doesnt look promising
I can't see it being possible at all due to the fact of the required depth of most 6.5's and speaker excursion. Any baffle/adaptor you build would not allow the stock panel to fit flush again, even if it's a 1/4 in thickness. The metal that needs to be cut in order for a 6.5 to fit isn't structual metal, if you dont have access to a air saw or nibbler a good pair if tin snips will do.
