Are Rockford Fosgate Punch 25 to Life's Banned from comps?
They might let you do that up there, but if you read the class matirx it states under amplifier quanity one. Granted if its a local sho the judge might let it slide especially if the othe ramp is on highs, but at regional or multi point events they make you sitck to the rule and will have you pull the amp to the highs, some settle for just removing the fuse others make you pull the amp from the car.
Its about 15 pages of readin but the first page sums it up pretty well.
http://usaci.forumotion.com/general-discussion-f11/ddm3-protest-results-t3219.htm?highlight=ddm3
you are correct. that makes no sence really. you should be able to have amp on your highs but have to add the power. it should be one amp on subs and one for highs. they should change that i think.
Well, I thought this was my 25 to Life Punch 150's birth rating, but it is 1hawaii50's... Regardless, not bad for an amp rated @ 150 watts RMS stereo or 180 watts RMS bridged:
Cameron_B
Single Cab Loud
Cameron_B
NC
gunz4me
