Are mtx amps underrated
Yea I Found That One All Ready But I Would Like To Know If Thats Close To Acutal
Plus He Said He Took It Out Of His Truck Because It Make A Whoo, Whoo Thrugh The Sub
Is It Fried Are Was He Doing Something Wrong
Iam Considering Buying It,,
"MTX Thunder 152
2-channel power amplifier
This is a USED 2-channel amp from MTX. MADE IN THE USA. It is in perfect working order. I have bench tested the amp to assure NO DOA. Cosmeticaly it is in Very Good condition with only some scratches that have been touched up. Full diagram of amp is on the base of the amp to make installation a breeze. Original box and manual are not included.
37.5Wx2 into 4 ohms (75Wx2 Peak)
75Wx2 into 2 ohms (150Wx2 Peak)
150W RMS bridged into 4 ohms
325Watts Dynamic Power Bridged into 4 Ohms (14.4VDC)
110 dB Signal to Noise Ratio
Crossover, variable 40Hz to 200Hz, 12dB/octave high-pass, 24dB/octave low pass
Bass boost @40Hz 0-18dB
Can run in 3-channel Bridged/Stereo Mode
Recommended application: Best for running a pair of 6x9", 6.5" etc in stereo, or wire the amp mono to an efficient single woofer in an enclosure. Built-in x-over will allow all applications.
Use the shipping calculator to get a great price on shipping !
Feel free to ask any questions."
^^that's all i got outta the ad. no "whoo whoo"
No I Was Thinking About Buying One From A Friend
But Didnt Know If The Amp Was Making A Whoo, Whoo Meant That The Amp Was Fried??? Are If He Didnt Know What He Was Talking About
Dude if you're not 100% sure it works then leave it alone. I love MTX (I'm using 3 of 'em), but you can get it anywhere! Those amps are all over the place. If you like that particular model you can find another I'm positive. I would just tell your buddy thanks but no thanks.
Also most MTX amps have an unregulated power supply and are rated at 12.5 volts, so usually they will put out considerably more power when you put them in your car.
dflw_99
Kicker Ownage
dflw_99
OPP,AL
characterzero
