Are digital amps better?
c_james_s
SQ over SPL
hey, I was curious how and why digital amps are better? I hear that they draw less power from your battery and help with dimming headlights.are there any other good things about them? I hear they have no need for a dac since they are all digital?
Digital amps = Marketing hype
Well, unless you have a fiber optic output on your head unit running to a fiber optic processor that in turn runs fiber optic outputs to your amplifiers. Then again, why would one want to spend all that $$ in something that has a 60 decibel, or greater, noise floor at highway speeds is beyond me....
OMG, I HERE JL ADDS 12.4 DBZ AND MADD SQL!!!
Yes...
WHENEVERTH THY NEEDTH MADD SQL, SIMPLY TWISTH THY JL AUDIO BASS KNOBZ INTO THY MAXIUM SETTINGTH.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
"Digital" (class D) amplifiers use a technology that produces a sine wave with the peak and the trough cut flat. So if you use it for full range audio there will be audible distortion compared to other designs. However, the boards are designed so they draw less current so they don't get hot or require as heavy a power feed. They are ideal for powering sub woofers because at those frequencies the human ear cannot discern the distortion in the sine waves.
c_james_s
SQ over SPL
c_james_s
usa
squeak9798
