Are Amps RMS ratings at 14.4V ?
I believe that the ones that don't specifically state the voltage it was measured in, I think it's measured at 14.4v or even higher(meaning that your voltage has to be more than perfect to put out what they say it does).
i try to go by the fuse rating, which is not 100% accurate but sometimes can be close enough, and minus %20 efficiency
Then I hope you never have to judge power rating by a Zed amplifier then. You'd never be able to believe it does 1.5K on 40A of fusing.
that baffles me
Comes down to a lot more than what fusing is needed to protect the amp. There's a great writeup in the Zed manuals about how amp fusing ended up becoming a marketing technique for a lot of companies as well as some other industry myths. Definitely worth a read
My M3a has a 250a fuse rating but T-Fade clamped one putting out 3900 rising to 1 ohm dropping to 11.2v.. Of course that will be lower at 1 ohm nominal, but still, it's super efficient. MMATs and Zed (like you mentioned) along with several others are in the same boat.
To help others understand... Music will draw much less current than a sine wave. Also, a fuse can take around 1.5x of it's rating for short bursts. Fuses rarely pop on quick bass hits.
Cpita
Cpita
Midland, TX
SounDrive
