Arc Audo Flatline : Sealed or Ported?
Ts619
Hey guys, first system, first sub. Just wanted some opinions on which should I go with for my (1) 12'' Flatline D2which is goin into a 2001 BMW 330 Coupe.
The website Arcaudio.com suggested
Optimum sealed enclosure : .9 cuft
Ported enclosure : 1.8 cuft @32hZ
Any help/advice would be great.
Oh yea, im runnin a 1500 XXK to this sub if thats a factor into this.
Ts
Ts
Ported if you want a lot of output, sealed if you want tight, consistent bass response.
I listen to anything that sounds good, rangin from country to rap to techno. For that type of music would you guys choose Sealed?
And thanks =), My brother has been into car audio for a while n made sure I got a great set up
Yeah, I'd go with a sealed box... Might want to add a bit of volume to it though... With my flatline, I found that I got a real good sound out of 1.2 cubes. Before displacement, that is.
Thanks for the opinions and replys, but those of you who did reply, would it be too much trouble if you could give me some reasons why you chose sealed or ported?
Thanks
Ts
although arc states that it is a "small sealed enclosure subwoofer", there are a few things that suggest otherwise...
Qes=0.367
Qts=0.332
Fs=23.2hz
EBP=63.2
chances are that your end product will be favourable regardless //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I would personally go sealed.
Off-topic: Where in Indiana are you located Ts619? Hopefully close by so that I can hear that Flatline //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Ts619
Ts619
Indiana
Ts619
