1. Product:
arc audio kar series 1000 watt monoblock black amp (ks1000.1)
2. Specs:
Advanced microprocessor control system
Non digital class H switching design
Code based flashing diagnostics
Designed By Robert Zeff
Protection against: Reverse voltage, Over Voltage, Speaker Short, and Thermal Overload
Can drive highly reactive loads
Hi/Low Level balanced switchblade RCA inputs for flexible integration into most applications
Optically isolated Mosfet power supply
24dB lowpass crossover with 30Hz to 250Hz
Master/Slave control
Variable Sub Sonic filter
Variable Bass Boost
Quiet Fan cooling
Strapable Design
Power output RMS @ 4 ohms 1 x 850 watts
Power output RMS @ 2 ohms 1 x 1000 watts
Power output RMS @ 1 ohm 1 x 1000 watts
Transient Distortion (400W) Frequency Response 20Hz - 250Hz
Signal to Noise Ratio (A wtg.) >112dB
Bass Boost +15dB@10-125Hz
Crossover (Butterworth) 30Hz - 250Hz variable 24dB
Fuse 25A x 4
Size 15.0 1/2"(L) x 8.0"(W) x 2 3/8"(H)
3. Description/Condition:
used amp
some chips and kinks on amp and mounting feet
RCAs are in good shape and are not loose
amp is in good working order
4. Price: :
$300 shipped, insured, paypaled
this will be shipped from modesto, ca. 95355
5. Pictures:
2. Specs:
Variable Bass Boost
Quiet Fan cooling
Strapable Design
Fuse 25A x 4
used amp
4. Price: :
5. Pictures:
