arc audio kar series
Joemon
1. Product:
arc audio kar series 1000 watt monoblock black amp (ks1000.1)
2. Specs:
Advanced microprocessor control system
Non digital class H switching design
Code based flashing diagnostics
Designed By Robert Zeff
Protection against: Reverse voltage, Over Voltage, Speaker Short, and Thermal Overload
Can drive highly reactive loads
Hi/Low Level balanced switchblade RCA inputs for flexible integration into most applications
Optically isolated Mosfet power supply
24dB lowpass crossover with 30Hz to 250Hz
Master/Slave control
Variable Sub Sonic filter
Variable Bass Boost
Quiet Fan cooling
Strapable Design
Power output RMS @ 4 ohms 1 x 850 watts
Power output RMS @ 2 ohms 1 x 1000 watts
Power output RMS @ 1 ohm 1 x 1000 watts
Transient Distortion (400W) Frequency Response 20Hz - 250Hz
Signal to Noise Ratio (A wtg.) >112dB
Bass Boost +15dB@10-125Hz
Crossover (Butterworth) 30Hz - 250Hz variable 24dB
Fuse 25A x 4
Size 15.0 1/2"(L) x 8.0"(W) x 2 3/8"(H)
3. Description/Condition:
used amp
some chips and kinks on amp and mounting feet
RCAs are in good shape and are not loose
amp is in good working order
4. Price: :
$300 shipped, insured, paypaled
this will be shipped from modesto, ca. 95355
5. Pictures:
Way to put personal info online, Thanks!
i think he is just trying to show that he shipped and document it so that more than just me and him know whats happening and its not back firing and becoming a scammer bash thread.
now stop being a tool and post dumping
Joemon
Joemon
Modesto, ca.
onelivinlarge
