ARC Audio DXE Very Rare
wanderer1
Item(s) for Sale: For sale is a like new ARC DXE. This thing is extremely capable and very rare. Incredible processing power and all balanced connections. Can run 4 way active if you'd like, has number of presets to recall. Fully balanced signal from head unit to control unit. Clipping lights. Dual input. 5 band parametric eq. 3 summed sub and center channel. Once you have it set you can remove the control unit and out it away. You still have the 5 band EQ with volume and fader control. Adjustable crossover slopes and on and on, the manual is 20 pages long, please refer to it for questions, it can easily be downloaded at the ARC Audio site.
like new, would consider new. just came back from ARC today after a full check up. the cables have never been used. Pretty sure it was just mounted on a display board.
$800 (original price was over $1700)
Actual shipping will be figured out
has badd *** eq and can go active on bass and adjust level, 6db to 48db slope etc. then split center channel if you want. $650 cheap for what this thing does didn't think it would not fly and go 2 pages for all it does and the digital interconnects. PM me gixxer see what we can do
ended up with a DEQ.8, for less than 3 bones. that is all could swing right now... The wife's Volvo is down and out right now, the step daughter decided to run it off the road, and took out the lower valance, intercooler, radiator, and bent the outer tie rod end .... I have to fix it this weekend. cha - friggin - ching $$$$$$$ !!!
I REALLY wanted this though. AWESOME unit here guys and gals ......
Trying to get system installed in 2 weeks and need the cheddar that's why i'm taking a loss here. Have speaker setups fo sale too. Needs to go so I can get rockin and who ever gets this will be rockin too not only can each driver have independent gain adjusted higher or lower than the other drivers in the bunch it comes with a 5 band parametric eq whose centers can be adjusted and tailored for your use. Hybrid x-over and adjustable parametric eq, add it up. till Sunday its more of a steal, I feel its easily worth 750 or more but the buy public will set the value. also remember it went to ARC for a full checkup in April. Read the manual if youre interested
$500 shipped conus is best I can do for the Bob Zeff designed hybrid digital xover with 5 band with adjustable center points parametric EQ come get it. Work trade for cash and ARC KS 300.2 or 300.4
wanderer1
wanderer1
Laughlin
wanderer1
