HiFonics CLEO 3 Band EQ and Level Adjustment
wanderer1
Item(s) for Sale: Frequency Bands: 3
Center Frequencys: Variable
Band 1: 23Hz-47Hz
2: 185Hz-375Hz
3: 12KHz-24KHz
Maximum boost/cut: +-12dB
Frequency Response: 5Hz to 50KHz -3dB all controls flat
Signal to Noise ratio: 103dB A-weighted
THD and IMD: Less than 0.02% at any output
Slew rate: 11V/micro second
Channel Seperation: 80dB
Maximum output voltage: 2.7 V RMS
Maximum input voltage: 2.7 V RMS
Input gain range: 0dB
Output gain range: 0dB
Input impedance: 15K ohm
Output impedance: 300 ohm
Supply Voltage: 9 V to 14.4 V negative ground
Current consumption: 400 mA
Size H x W x D 25.4 x 178 x 89
Millimeters / Inches: 1 x 7 x 3.5
A little scratched up but all the writing is legible. Wires are still long on the harness.
$50
Free
wanderer1
wanderer1
Laughlin
wanderer1
