AQ3500 or Crescendo 3500?
AQ is rated at 4300watts, so it does not do over rated.
Why fuse from batts to amp, assuming your runs are short and not in danger or shorting on anything.
For a 3500.1 with an HO alt I'd do 2 G31 batts in the rear, more if you play long periods at full tilt...
I meant that one the basis that its called a 3500 but does more, lol
That's exactly why I run them, safety precautions, would much rather replace a $1 fuse then spend $200 to get all the fets and **** replaced
And okay sounds good, I just need to pick up another Deka and ill be good then
04murdalanche
Dallas, Tx/Ada, Ok
04murdalanche
