AQ substage not what i expected
Harleyfx69
audio n00b
2 aq 2200d daisy chained at 2 ohm load,
2 aq hdc3 dual 12 " dual 2 subwoofers,
full zero gauge install
box around 4.25-4.5 cube's tuned to 38hz
The system flexes the doors , the windows, and a slight movement to roof ..
But you can barely hear it outside,
and its still tolerable to listen to at full tilt on the inside ..
extended cab truck with rear seat replaced with this box ..
is this about what this should put out ?
or should it be putting out a lot more ?
same with my setup man i got 2 l7's 12's ported tuned to 34hz 5.2netcuft on 1500rms and its in a 01 f150 4 door with sub up and port back and it gets loud on the inside but outside you cant hear it like some cars
thats the way it should be.
unless the windows are down.
i always hate hearing rattling or loud music outside the car.
some sound good but most are just loud systems that sound like a$$
i knwo what ya mean on hearing it outside,
Just trying to give a description,
I also have the cummins diesel engine which is very loud and masks the outside noise ..
and the subs are set up in a TOTAL 4.5 cube box, its something like 6 not taking out port displacement and sub displacement,
the subs are dual 2 ohm although i dont have a DMM to confirm,
That is what i ordered, and the order confirms that,
and im uploading photos to photobucket now .. give me like 5 minutes for them to get on
I never understood people wanting to hear it on the outside, all it does is piss people off unless you are rolling in the ghetto.
That being said that shit should POUND there has to be something else wrong.
yes i have the electrical to back it up,
dual heavy duty batts, and a 140-150 amp alternator ..
Thats not really enough electrical to be honest. I would recommend at least 200 amps for the alt and three very good batteries or four cheaper batteries.
Edit: Im guessing both batts are under the hood? How many runs of 0 ga are you running?
Harleyfx69
audio n00b
Harleyfx69
arizona
Crimson Boom
michigan born
    May 14, 2026
michigan born
    May 14, 2026
