sundownz
Pro Seller
Supporting Vendor
I've started to test all of our drivers on a 60 Hz sine wave test... they must pass at LEAST 5 minutes at rated power, clamped, to receive a given rating. Being 60 Hz it's pretty brutal as excursion is quite low. All drivers to come from us from here on out will have passed this test and still be fully functional.IIRC most manufacturers(at least the popular underground ones that I can think of) rate their subs based on continuous power handling for a given amount of time. So unless you're playing pure sine waves, you can theoretically play music with a good deal more power on tap in order to feed it more power during the musical peaks in the song, so long as you're not pushing it past mechanical limits.
I've already used the data to improve a product I'm releasing next year -- I upgraded to a higher temperature coil as the driver actually did pass the test initially but the coil adhesive was damaged and it failed soon after on music. Very useful data, IMO.
