AQ hd318 box help ..
what is the mounting min depth for the hd318 ? and what tune should i have/ size of box for a daly driver
and i am going to run 1800 to 2000 watts
thanks chase...
Mounting depth not listed on website but i'd guess its prolli 9.5 - 10" deep, then add like 3 or 4". At least that is what i normally go by, unless i have sum serious space constraints.
Box size i'd say like 6.5-7ft3 @ 36-38hz w/ 80-95sq in of port, anywhere in that size/tuning range should work out pretty well.
Audioque recommends 6 cubes, but you could definitely go bigger. If you are limited on space, do aeros. They won't take up as much room as a slot port. If you need help designing, pm me I can help with your design.
24
24
0000000___________________
000000|00000000|000000000| 18
_______00000000|000000000_______
|00000000000000|0000000000000000|
|00000000000000|0\30\000000000000| 12
_________________________________
38
all the 0s are blank space .. it wouldn't let me leave open space idk why hope that helps
the hight is 17
Yeah but if you only have 7 ft to work with you dont want to choke off your hatch especially if you have port and sub back or sub up port back. Youd be better off with the 15 giving it the right box and room for the bass to get into the cabin. Unless you wall it.
chasepb
chasepb
cameron,NC
chasepb
