Aq 3500d?
Yeah, but I don't see but one set of power/ground inputs.
Im sure it might not "need" em but its getting close to the point where I think they need to be there.
My mojo 4kw's made an isht ton of power with single 1/0 inputs, and they aren't efficient at all. Like 74%.
Well its no different then like a Atomic 3000.1 or sundown SAZ3000d, they do 3500wrms@1ohm, and do a lil over 4kw @ .5ohms, with only one set of power/ground inputs!!
But I would love if DJ would come out with a bigger amp, id get one for sure, to run my 10" HDC3s, but for now they will be on a MM4000.1@ 1ohm around 4.8kw for daily!!! But id switch to a big AQ amp in a heartbeat, i like having matching equippment!!
Ive also heard they catch fire for no reason also.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
But seriously, Im just stating my opinion. I didn't say they was needed, Im just saying, its gettin close.
Look at the 40.1. Its rated at 3600rms and has dual power/ground.
Im about overkill anyways.
There both rated at 3000rms also.
But you also gotta think, that board "should" be more powerful than the Sundown/Atomic board.
And I already think the Sundown/Atomic is pushing the limits.
When you say pushing limits what are you meaning?? Because my mojo 4kw was doing like 4.4kw and only one power and ground terminal, now my Autotek MM4000.1 has dual power and ground terminals, but they also do upwords of 5kw!!
I mean, the power wire can't stand 400amps of current.
Yeah, a short run, or for a few seconds.
I'm just saying, Id rather have dual power/ground outputs on a 3.5 rated RMS amp than 1 set on a 4kw amp.
Seeing, more current to the amp=more power. In theory.
It's a valid argument.. I would like to see dual connections as well.
Well id agree with ya to!! I was just making sure i knew what you ment!! LOL, but yeah i would like to see that happen!!! I was thinking about two AQ 2200s but i got the big MM4000 now so im gunna wait and see if this big AQ amp happens, ill order one asap!!!
I personally don't think it would make a dang bit of difference, but that's what this thread is for.........tell him you want the amp, and what you want on it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ill take a 25k watter if he'll build it //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Jeremiah25
Team Budweiser
Jeremiah25
Springfield, MO
brucebruce1546
BP1Fanatic
BP1Fanatic
