AQ 2200D tested!
Thanks for doing the testing man, debating on whether getting a 1200D or getting the 2200D. Not really a money problem, just didn't want to spend that much.
1/0 input terminals. I think every amp over 500 watts should have them.
Preaching to the quire! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Lol.
But yes I also appreciate this thread, the testing, and the information on real power versus apparent power. That stuff was a good read the other day.
J25: hey i was just looking over this thread again and i thought back to your HDC thread about the testing you did. didnt you do a 143+ with 1 hdc and 1 DD m1a? and in this thread you're pulling a 143+ with the Aq 2200d.
isnt the m1a a 1200w amp?
maybe different boxes??
i think its the same box (he says its the same box from the 1200d tests, but i dont know if thats the same box he did for the "hdc" tests), however i just noticed he is using an HD and not the HDC this time around. i remember his HDC pretty much killed his old HD so that could be why.
Yeah, it did almost a 146 with the HD3c. Look at part 2 of the test. Another thing to consider is my windshield is pretty severly busted now, and wasn't before. I busted it breaking ice off of it this winter. I haven't referenced the car with the busted windshield against what it used to do before it was busted. It may have lost a little.
Wanted to add my finding from today.
I tested the pair strapped to my DD 9515's in 10.5 cubes @ 40hz.
Test Frequency 43 hz
Resting load 0.6 ohms
Resting voltage 14.38 volts
Voltage dropped to 13.2 volts at burp
72.4 volts
47.2 amps
3417 watts @1.53 ohms.
This is just an example of the aparent power a pair of these are producing in my application. These numbers will change dependent are your subs, box and feed voltage. Also the pair strapped is rated to be stable at 2ohms.
Jeremiah25
Team Budweiser
Jeremiah25
Springfield, MO
BassAddictJ
