AQ 2200D tested!
Part 1:
I used one of my old HD3 12's with dual 2 coils. Amp running at 1 ohm nominal. The is the same box I used to test the AQ1200 and the HD3c's when they came out.
VAC: 66.2V
CAC:16.52A
Apparent power: 1093.624 watts
Reactive Impedance: 4.007 ohms
TL score: 143.8 legal dash
Compared to rated power: 1093.624/750 = 1.458 or 45.8% over rated power!
Part 2 comming soon
OK, is the 1093.624 at 1 ohm or 4??? Confused
1 ohm is nominal, but anytime a speaker is played it has something called impedence rise which raises the resistance the amp sees. Keep your impedence rise low and you get more power; however stiffer boxes usually have better spl, but more rise. Its a give take kinda thing that you really have little to no control over
Part 1:
VAC: 66.2V
CAC:16.52A
Part 2 comming soon
I need to buy you a beer. Thanks.
its is WIRED to 1 ohm. it ROSE up to 4 ohms at that particular frequency //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
WoW! Is this what everyone keeps calling "Box rise" or is that something different? I didn't know this was possible. I thought once you wired down to 1 ohm you were at 1 ohm..How do I keep from having this impedance rise? I dont want it..yuck... How ever I DO want this amp....BAD..Thanks by the way for your quick responses and thanks for posting the results of this test man..you guys rock!
Impedance rise is unavoidable. A coil moving in a magnetic field is going to have a lot of inductance. Inductance causes a change in impedance. Even without a box or a car, you still get some "impedance rise" because of this.
It's really not something you need to worry about. Just hook the amp up a 1 ohm like it's recommended, and you will have plenty of power.
//content.invisioncic.com/y282845/emoticons/imwithstupid.gif.ff72b14418b3c35ebdf1ccd38da21695.gif
x2
werd
OK, so I didn't really post much about the amp other than power, so I'll take a min and post some general thoughts on the amp for the other factors.
Good:
I love the fact that this amp has a clipping indicator built into the remote gain control. Just mount the knob somewhere that you can reach/see it, and you can tell if you are clipping the amp at a glance.
The amp is very dynamic for a class D amp. Even at low volume levels it has a lot of punch, and picks up all the quick, tight transients. This has been my biggest gripe about the AQ1200 and the DD M1a, as they don't do this particuarly well. This amp is much better.
Beat the crap out of it, and it's still cool to touch.
Turns on/off almost silently.
Small footprint/good power
Looks. Can't go wrong with plain black and a simple logo.
1/0 input terminals. I think every amp over 500 watts should have them.
Price (obviously)
Bad:
No bass boost, phase control, blah blah etc.... knobs. I personally don't give a crap if they are on there or not, but some people may. DJ left them off for some noob protection, and I can definately see his reason.
Can't shut the subsonic or LPF off. I know it's a sub amp, but I like to shut these off and use my active crossover to control everything. Not a huge deal, but something I prefer.
Can't really think of anything else I didn't like
I like this amp so much, I'm trying like h e l l to talk DJ into a 3000+ watt amp. He's fighting the urge, but I think we can break him down. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Jeremiah25
Team Budweiser
Jeremiah25
Springfield, MO
BassAddictJ
