AQ 2200D tested!
Jeremiah25
Team Budweiser
Part 1:
I used one of my old HD3 12's with dual 2 coils. Amp running at 1 ohm nominal. The is the same box I used to test the AQ1200 and the HD3c's when they came out.
VAC: 66.2V
CAC:16.52A
Apparent power: 1093.624 watts
Reactive Impedance: 4.007 ohms
TL score: 143.8 legal dash
Compared to rated power: 1093.624/750 = 1.458 or 45.8% over rated power!
Part 2 comming soon
Part 2:
I picked up the old HD3c 12 prototype from AQ (I'll admit I missed it) Dual 2 copper coils. Running the amp at 1 ohm nominal.
VAC: 65.9V
CAC: 19.39A
Apparent power: 1277.8
Reactive Impedance: 3.4 Ohms
TL score: 145.7 (legal dash)
use a pair of the old hd's @ .5 ohm roll into the volume and see what kinda power we can get @ 2 ohms //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There is a part 3 comming....sometime. Probably with 4 12's though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif (I'd have to build a box or use a prefab for 2 12's.......I'm way too lazy)
What kind of power supply you giving it? 4ga or 1/0 power wire, battery? Voltage drop?
Good info so far.
2 NSB 90's and about 20 runs of 1/0 to my distribution blocks. I've just got 4 ga running from the dist. blocks to the amp. I might stick some 1/0 in there to see if it gains anymore.
Jeremiah25
Team Budweiser
Jeremiah25
Springfield, MO
BassAddictJ
