apx 10
  • 6
nuboot
i will be getting started on my build as soon as the sub gets here. its for a local show on the 27th. currently the stae record is
Class A - 1-101 sq. inches
149.4db SKY PAMATIGAN @ PROGRESSIVE COMP JUN 2009
1995 Chevy Blazer(4dr)
Digital Designs 3510d
Sundown Audio SAZ-3000D(x2)
i have a 2005 trailblazer and currently clif designs 4800 i would like to get another 1 but i just spent to much money getting my atomic 3000.1 back from atomic. so now i only got around 5k i want to give this guy a pretty good run for his money but i cant decide how to build the box any help would be greatful
That means your cabin gain should be 48-50 Hz if you stay in the trunk.
For an APX 10, I'd try around 1.5 cf, and tune around 45 Hz, with 40-60 sq in of port area. There are differing opinions on what works best, but it's one of the 3 configurations:
subs & port back
subs up, port back
subs & port up
Good luck at the comp! Single 10 with 5kw should do OK. Tune it up properly, and I'd bet you could hit mid to upper 140's
Yeah... I didn't check the huge wattage people are using for these... you're underpowering it... so a bigger box is better.
Not sure the optimal size, but you want it to make the 5000w cause nearly full excursion.
I was just suggesting an "off my head" number earlier. My next "off my head number" is 2.5! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I ran a 10" with triple spider pack in ~2.7cf daily, but I only had 1200w to her lol:laugh:
I just read Atomic's enclosure design guide. It's in their Downloads section.
APX12 = 4 cf, and APX15 = 6 cf... the 10's not listed, but I imagine it's between 2.5-3.0 cf.
They also are all tuned to ~60-62 Hz for peak SPL... but you'd want to verify the best tuning yourself.
Also, they recommend 5000w for SPL on the design guide.
nuboot
nuboot
lawton, ok
nuboot
    May 20, 2024
    May 20, 2024
