apx 10
nuboot
i will be getting started on my build as soon as the sub gets here. its for a local show on the 27th. currently the stae record is
Class A - 1-101 sq. inches
149.4db SKY PAMATIGAN @ PROGRESSIVE COMP JUN 2009
1995 Chevy Blazer(4dr)
Digital Designs 3510d
Sundown Audio SAZ-3000D(x2)
i have a 2005 trailblazer and currently clif designs 4800 i would like to get another 1 but i just spent to much money getting my atomic 3000.1 back from atomic. so now i only got around 5k i want to give this guy a pretty good run for his money but i cant decide how to build the box any help would be greatful
That means your cabin gain should be 48-50 Hz if you stay in the trunk.
For an APX 10, I'd try around 1.5 cf, and tune around 45 Hz, with 40-60 sq in of port area. There are differing opinions on what works best, but it's one of the 3 configurations:
subs & port back
subs up, port back
subs & port up
Good luck at the comp! Single 10 with 5kw should do OK. Tune it up properly, and I'd bet you could hit mid to upper 140's
Yeah... I didn't check the huge wattage people are using for these... you're underpowering it... so a bigger box is better.
Not sure the optimal size, but you want it to make the 5000w cause nearly full excursion.
I was just suggesting an "off my head" number earlier. My next "off my head number" is 2.5! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I ran a 10" with triple spider pack in ~2.7cf daily, but I only had 1200w to her lol:laugh:
I just read Atomic's enclosure design guide. It's in their Downloads section.
APX12 = 4 cf, and APX15 = 6 cf... the 10's not listed, but I imagine it's between 2.5-3.0 cf.
They also are all tuned to ~60-62 Hz for peak SPL... but you'd want to verify the best tuning yourself.
Also, they recommend 5000w for SPL on the design guide.
nuboot
nuboot
lawton, ok
nuboot
BP1Fanatic
BP1Fanatic
