AP3K on a XXX15D2; 1 ohm or 4 ohm?
Never max out gains, never. Go 1ohm and set gains properly. Headroom is a good thing.
Since this amp is only rated at 2 ohms, will I risk damaging the amp at 1 ohm? Even though I will only be running at 1/2 power or less (assuming 4-5Kw at 1 ohm)
no offense but that amp probably does around 2500clean @2ohms anyways if your lucky I would sell and get something else. Top notch sub but bottom of the barrel amp shouldn't go together imo
I ran the amp 1 ohm stereo so I had to test per channel. I am honestly pretty amazed about it
20.4 ampsx 45.8 volts so 934.32 RMS per channel so 1868.64 RMS with imp rise 2.25 per channel so 4.5 ohms basically bridged and still did 1868 watts ... also to top it off!!! Dropping to 11.8 during test!!! It is rated 3000 at 2 ohm mono and 2000 at 4 ohm... And I got over 1900 at 4.5 at 11.5 so I am pretty sure this amp does rated and maybe then some. Now I am sure distortion rates were high but for what the amp costs. I did have a problem with it clipping out on my twice while driving on high freq but i am going to cut it some slack for now. I have a battery in the rear But I have cheap 4 gauge going from batt to amp and I am using a so so grounding point which I have the battery grounded there with 4 gauge and 4 gauge from the battery to the amp so perhaps it is getting some restriction.
-Not me-
"Yeah the GD6001 will do around 3kw at .5ohms all day long and its rated at 2000x1 at 1ohm, I ran two of them, and then Two of the AP30001s and they hand the kx/zx2500.1 there *** for alot cheaper, and in my mind very **** amps!!"
Basically I want to give it 2,000 watts, want to know which load would be the best.
I'm not too keen on ohm loads and whether this amp will be ok at 1 ohm even witht he gain 1/2 way up.
Real World AP3000D Tests !!!! - Car Audio Classifieds
So tonight we took a few hours and sdelthon and myself did some testing on one of my Audiopipe AP3000Ds, I havent clamped one of these for some time now, and wanted to do a nice lil test and result page about them!!
Car used sdelthons 94 T-Bird
Deck used Sony CDX-GT63UIW 2volt preouts
Stock ALT
1 run of 1/0 Audiopipe power
2 Treo SSX100Bs and a Treo SSX75B
1 Ap3000D
2 Treo SSPs 10s dual 2s reading slightly different, final ohm load before rise coming out at 3ohms
Ohm Load calculated after imp rise
So after 2 hrs of play time and a weak charging system the amp is still very strong, and if we could hold in that 14volt range at 2-2.5ohms we will be able to get all of 3kw+ like rated then some, so for $299shipped with warranty these are the best amps on the market for the money, and ill be running 4 of them!!!
Audiopipe AP3000s amp gain lil below half
Test#1
Resting voltage-12.50volts
Voltage drop-11.6volts
Power-2014.32rms wattage
Ohm load-3.77
Amps Voltage-87.2
Amp Current-23.1
50hz test tone
Deck sublevel at +6 out of 10
Volume 30/50
Test #2
Resting voltage-13.88
Voltage drop-12.5volts
Power-2489rms wattage
Ohm load-3.6
Amps Voltage-95.0
Amp Current-26.2
50hz test tone
Deck sublevel at 10 out of 10
Volume 30/50
Amp gain lil over 1/2
Test #3
Resting voltage-13.83
Voltage drop-12.5
Power-2675.34rms wattage
Ohm load-3.7ohm
Amps Voltage-100.2
Amp Current-26.7
50hz test tone
Volume 30/50
Final test with video
Resting voltage-13.66
Voltage drop-12.4
Power-2525.95rms wattage
Ohm load-4.208
Amps Voltage-103.1
Amp Current-24.5
50hz test tone
Volume 35/50
mugen08
Win aplenty
mugen08
Outside the box
mugen08
