ap30001d wiring?
I believe the 12W7's only come in single 3 ohm coils, so you can either wire them in parallel to 1.5ohm nominal or in series to 6 ohm nominal.
The Ap3000 is 2-ohm stable, so you should be fine wiring in parallel to 1.5, hopefully box rise lifts you up a bit. Wiring to 6 ohms would just be silly, lol.
I could wire them together at 1.5 ohm and get around a little over 2k.. would that be safe to run on them?
OR
I could wire each seperate into each side for about 750 at 3 ohms?
not sure if those numbers are right
the ap30001d is 2 1500s strapped and you can run it using 2 channels or bridge it and internally strap them
get a real amp? other wise if ur electrical is good i mean really good wire them to 1.5 and run like hell lolz
heard those mb quarts are nice... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
OR
then why the fuck did you post them? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
blabo219
blabo219
Battle Creek, Michigan
Annnarbor84
