daboyfrumdabx
This. Just in case you upgrade. You don't need the speaker wire to handle 240 watts since each wire will only see 60. I'd go 16 at a minimum and larger if you can afford it. If you go 16, make sure it's true 16. Anything less and it'd barely be an upgrade from stock wiring.
