anyone use imprint processor kit?
doox00
I have a 9887 deck, was looking at the imprint stuff. Overal seems pretty neat.. just not sure its worth the money. Anyone have this setup? What all do you need to use it? I see there are two different things out there, the KTX H100 and the PXA H 100, do you need both with the 9887 deck?
thanks
the 9887 has everything built into it already that the imprint kit would give you with the exception of the auto-tuning ability. there really is no need for it with that deck unless you have money to waste. if you do then you would need the KTX-100EQ.
the ktx-h100 (mic and software) and pxa-h100 (actual imprint processor) are for the lower models, like the 9886 and the ida-x100. the ktx-100eq gives you everything in one unit and does not need to stay connected to the 9887. the pxa-h100 must remain connected at all times and does not require the ktx-h100 unless you want to use the auto-tune feature.
doox00
doox00
Michigan
nineball
michigan born
    May 14, 2026
michigan born
    May 14, 2026
