Anyone use a "milkshake" to seal off the inside of an enclosure?
ty1er
Finishing off the Inside of a sealed fiberglass enclosure. Does anyone use a milkshake mixture as an extra protection to fill in any tiny pin holes that may have been miss while fiberglassing?
If so, how exactly do you make the so call milkshake mixture?
thanks
-ty1er
You can , just mix the resin and filler together to a soupy mix . If you have a bunch of sanding dust from filler , you can just mix some of it in some resin for the same affect. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I believe most just use the paste mekp . I don't use the shake method . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks
-ty1er
you dont use a milkshake on the inside you use a milkshake on the outside. You use a thixotropic on the inside. 2 different things, milkshake is autobody filler and resin, where thixotropic is cobosil, sawdust, or talc mixed with resin.
I ended up going with a 50/50 mix with the bondo/resin. I used both hardeners from each product. Mixed it all up and poured it in the box.
It seemed to work excellent.
ty1er
ty1er
Boston
ty1er
