anyone else want a folded horn designed for them?
Death By Bass
WHATS A SUBWOOFER!?!?!?
I'm in a good mood, and have nothing better to do, so, if someone is looking to get a folded horn designed, let me know.
would prefer if the enclosure was to go in an SUV, wagon, or van, as these are what a horn will work best in.
post your interest here.
I need full specs for the woofers, or as much as possible.
I'd also prefer it if the person actually made it... //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
The Mach5Audio 18"...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
T/S Parameters - MJ-18 - 8 / 4 Ohms
Fs = 30.4 / 28 Hz
Re = 7.2 / 3.2 Ohms
Qes = 0.39 / 0.34
Qms = 3.41 / 4.99
Qts = 0.35 / 0.31
Mms = 219 / 229 grams
Rms = 12.3 / 8.1 kg/s
Cms = 0.100 / 0.14 mm/N
VAS = 243.8 / 208.4 litres
Sd = 1029.2 cm2
Xmax = 12 mm
Cone Diameter = 36.20 cm
Recommended Box Sizes:
Sealed: 80 litres (2.8 cu. ft.)
Ported: 128 litres (4.5 cu. ft.) 30Hz tuning
EBS: 250 litres (8.8 cu. ft.) 18Hz tuning
Fs = 30.4 / 28 Hz
Re = 7.2 / 3.2 Ohms
Qes = 0.39 / 0.34
Qms = 3.41 / 4.99
Qts = 0.35 / 0.31
Sd = 1029.2 cm2
Xmax = 12 mm
maybe I should specify 12inch or smaller? :p unless you have the whole back area of a van?
I got a PM from someone aswell, however, neither of you specified a vehicle...
Ding ding //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
48" between the wheelwells really is the only constraint I have...we're talking 100+ cubic feet to play with here //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'd like one with this airbrushed on the baffle:
single eu700 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif please...for an HT setup..u still need specs?
Qts: .29
Qes: .30
Qms: 10.5
Fs: 28 Hz
Re: 3.2
Vas: 22 L
Mms: 50 g
Bl: 13.3 T*m
SPL: 85 dB
Sd: 114 cm^2
Xmax: 13 mm
Voice Coil: 38 mm
Magnet Width: 5.000"
Cutout Diameter: 6.000"
Mounting Depth: 3.500"
Weight: 7 lb
Total Height: 3.500"
Displacement: .04 ft^3
Outside Diameter: 7.250"
Death By Bass
Death By Bass
Adelaide, Australia
Megalomaniac
Mike Mccabe
