Anybody using these batteries?
Gearstix
Exide batteries.
Features
* Spiral cell construction provides unparalleled battery performance for cars, trucks and SUVs.
* Delivers up to 30% more cold cranking amps during the first five critical seconds
* Tightly wound cylindrical cells give added performance and durability
* Amp Hour Capacity: 50
* Completely sealed and maintenance-free (no need to add water)
* Uses AGM technology - battery acid is completely absorbed into cell material
* Recharges faster than a conventional battery (in approximately 1 hour)
* Resists vibrations 17 times more effectively than a conventional battery
I can get these locally for about 170 bucks each, I figured a couple of these would be cheaper than sourcing batteries out of the states.
Hmmmmm........I never heard of em wonder how they'd do. should get one write a review for us //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The brand is not Oribital IIRC. thats the series they are..
Its Exide Select Orbital .....
hmm.. I dunno it seems like its about the same as a Yellow top, which are around $250 each from a distributor...
dude jus get a yellow top, save your money. or a red for under the hood and a yellow used. dont half *** it.
or jus a get a powermaster d3100 and problem solved with one battery. lot of wiring using more than a couple batterys so its better to go with a single.
dude jus get a yellow top, save your money. or a red for under the hood and a yellow used. dont half *** it.or jus a get a powermaster d3100 and problem solved with one battery. lot of wiring using more than a couple batterys so its better to go with a single.
Theres no way I'm paying $250 for a 55ah Yellow Top. **** that
Gearstix
Gearstix
Alberta, Canada
Gearstix
