Any xbl^2 subs that are 2500-3000 rms?
IIRC, the UL12 does not employ xbl^2. I dont know of any xbl^2 that is rated that high, but my memory (on both accounts) may be off.
I agree, off the top of my head I cannot think of anything...
And the Critical Mass UL12 does not use XBL^2 technology, the website claims they use "MMAG" technology in the motor.
we may find out today what this can handle if I decide to recone it.....
Correct, the UL12 uses MMAG, which is still a split gap design, but in MMAG instead of using a single piece of steel with a rebate or 2 pieces sandwiched with a rebate they uses 2 thinner pieces of steel with no rebate and put a magnet in between the 2 top plates to form the rebate, hence MMAG - Multiple Magnet Air Gap.
I'm not really the person to talk to about that, someone else could help here..
but I'd assume maybe a flatwound coil, stiff suspension & stronger cone..
If you do that haven't you just created another generic high power handing woofer?
Somewhat, but the motor would still be XBL^2 lol //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
If the stock coil is roundwire you might increase thermal power handeling by using an edge or flat wound coil.. but you'd never reach the levels the OP is asking about without changing the wind width (which would mess up the XBL^2)
hornedfrog1985
<---Down Syndrome Tiger.
hornedfrog1985
Iowa
Electrodynamic
