Any Recommended 150-250 RMS Mono Amplifiers?
  • 4
pokeyouindaeye
Seeking a budget-friendly mono amp for a single sub... likely using a 4 ohm setup, potentially a 2...
Likely current sub options are likely an 8" ID or Rockford sub... 150w rms rated, waiting to hear which impedance.
- Image Dynamics ID8 or IDQ8, not sure which one or which... dual 2ohm or single 4ohm; 125rms either way
- Rockford P1S4-8, not sure if it's SVC 2 or 4 - 200w rms
Found a Hertz HE 1D.1 on Craigslist for $80CAD (about $50usd) 200w rms @ 4 ohm, SNR 100dba
But if that's not avail when I go to get it, any other fav. low-power decent quality new or used amps I should try to find on eBay or wherever?
Taramps Bass400
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
pokeyouindaeye
pokeyouindaeye
Vancouver, BC - Canada
pokeyouindaeye
slater
    May 2, 2024
slater
    May 2, 2024
