Any good 6 ch. Amp ?
Lots of people overlook Clarion amplifiers, but the XC6610 is absolutely worth consideration. It's small, all connections are on the same side, it's underrated, and the power is super clean with a silent noise floor. You can use as few as 2 channels of input and copy the signal to the all 6 channels. 85W x 6 @ 4 ohms, 125W x 6 @ 2 ohms, or 250W x 3 at bridged at 4 ohms. The icing on top is it's marine rated as well. This is a head-to-head contender to JL's XD 6 channel, except theirs is not for marine use.
i was thing of that one but at the same time the MB Quart NA540.6. which one is better? The zapoc is clean i know that but money wise is too much for this built.
LOOKING TO BUY A GOOD 6 CH. AMP TO RUN 4 6.5 AND 2 6x9.
Just a quick question.
Do you really need a 6ch?
If the 6.5's are mounted near one another, or your not going to use time alignment between the 6.5's....a 4ch will get the job done.
If the 6.5's are 4ohm.
Just a quick question.Do you really need a 6ch?
no, the 6.5's are going one on each door. 6x9 on the center console. so what u thing is best to run?
If you can't afford $275 for that Zapco the Clarion is also out of consideration. MB Quart is more budget friendly.
the Zapco is not 500 new? I want to put only new stuff.
When you're looking to put speakers in a center console you're no longer concerned about true sound quality, so just buy cheap power. I answered your original question assuming you wanted a certain level of quality. Most people who ask about 6-channel amps are not shopping with price as the top consideration. You could save money by buying a 4 channel and a 2 channel.
Is not that I want to be cheap, is that my budget got small b/c I went and got a arc xdi 2000.1 . So I'm trying get something in a good price for right now.
---------- Post added at 03:50 PM ---------- Previous post was at 03:50 PM ----------
Thanks trumpet for the info.
If ur not going active or care too much about ta just buy a ppi 900.4 plenty of power
el_papagallos
Pasadena Texas
momax_powers
