Any chance my amp is 1 ohm stable?
Assuming you're running a pair of D4 coiled subs... doubt the amp ever really sees 1ohm. Mine measure 2.6 at the amp and doing a 20hz-80hz sweep, never got below 2ohm IIRC...
I actually have three 4 ohm svc subs. But do you think they wouldn't drop to 1 ohm either?
Amp quality amd electrical play a big part. I don't think I've ever seem a sub meter exactly what its claimed to be.my "S6" sub meters 5.3, my "Q.25" sub measured like .38 or so... I'd say you'd be fine but its your amp. Wire them up in your box amd see what ya got
If you want to chance it it was a $30 amp. I have always tried to stick within the ratings on my amps since Ive generally bought new or amps I didnt want to purchase trwice. Not saying it cant Im just saying I wouldnt.However you could run two of the subs series wired and one paralled that would bring your load up.
I doint know what meter you are using or wire but I have all Fluke meters and I just tested 2 d4 subs from sundown a pioneer dvc 4 polk subs and 5 kicker paper weights Each coil was within .1 of the nameplate rating. Now if your connections arent quite right or wire too small that will add to the resistance. But I measured each coil then paralled and series then read and each time I was dewad on what I should have read except for the 2 that were bad. The tensile leads were off the sub so no reqading but if your 4 Ohm swvc doesnt read 4 ohm somethings wrong.
Fluke 115... the D4's are RE se-x's, Q.25's was an APXX18, the S6 is an orphan. I use 10/8 gauge OFC wire for the subs...
You only spent $30 on that amp, NOT a big loss if it does sh1t the bed, but I doubt you will have any issues, I've ran my Orion CO3002 (Made by Directed) @ 1 ohm bridged for months on end without fail (it's rated at min. 4 ohm bridged) - YES it did get pretty hot, but I made sure it was getting adequate ventilation & it never shut down on me 1 time... I still have this amp and it still works without problems and this isn't even a class D !!!
razaice
razaice
Detriot, MI
NIHL8ION
