Answer this !
the reason you get a reading of 11v is because your alt can't keep up with current draw from the a/c fan, lights, and etc. in this case, you are actually draining battery. a new alt will definitely help.
if it is doing that even without your stereo on, then your alt is toast, even my Monte with a 63 amp wont drop down below 12 volts, but you are getting a new one anyways, so what I just said was pointless
my alt makes more volts with more RPM.my A/C (fans) drop it down to 11v, even lower with the lights on.
It steals volts not amps !
Hopefully a new 245a alt will be replacing it, but its stock 104a for now
it steals both. you just don't have an amp meter to SEE it steal you amps.
supa_c
Abministrator
supa_c
In a chair
jellyfish420
NorthFramingham
    Jun 30, 2026
