Another which setup would you choose thread
Which setup?
  • Total voters
    17
Buck
little alien on campus
About 2400w rms for each setup
Would you do:
1. 4 12"s (most likely AQ SDC)
~600 rms to each sub. Total about 452 in^2 of sub area.
2. 3 15"s (please recommend 3 15"s for
~800 rms to each sub. Total about 530 in^2 of sub area.
Price is definitely a factor. I was looking at doing 3 SSDs, but they are 199, and I would prefer to get the BP power option, which would raise the total of all 3 to ~$690.
Ohms get weird in trio's though
Like .7 and such
I will get dual 4's, so they would wire up to 2.67 ohms, and that works out perfectly for me. If d4 aren't available, I can get dual 2's and wire them to 3 ohms, which would be pretty good as well. I already got that part figured out //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
if you do 3 15s i would wire them to .7ohm and not 2.67 because you are just gonna waste alot of power from you amp becasue after box rise you will be somewhere close to 4ohm
I'm running two nine.1s strapped, so .7=no. I really don't want to go below the recommended 2 ohms. At 12.5v I should see about 2000-2200w at 2.67 ohms. So at 14.4 (optimally speaking), I would see ~2400w.
o alright now i understand now i didnt know you were running thoes amps. I mean if you can figure out your box rise you might be able to wire them at 1.34ohm by getting dual 2s and get closer to max out from your amps
Buck
Buck
Inside of a pyramid
Buck
